It is currently Thu Aug 21, 2025 1:42 pm
PostPosted: Tue Sep 17, 2013 1:16 pm
First name: Steven
Last Name: Bollman
City: Emeryville
Zip/Postal Code: 94608
Hi,
I'm going to be gluing up the back sides of my new build. What is the best best glue for doing this?
Thx
__________
PostPosted: Tue Sep 17, 2013 2:00 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
If you're having to ask about the glue, you should probably put the BRW aside for the future. I'm not sayin' use cheap wood for your first build, but you should have a little experience before breaking out the BRW. Mahogany, maple, or East Indian Rosewood would be good choices to get the woodworking chops down.
For joining the backs, HHG(hot hide glue) or Titebond Original is used most often, but PVA, CA, and epoxy are also used.
Scrape the joint immediately before glueing, that raises the surface energy and improves adhension of the glue.
Do NOT wipe with any type of solvent before glueing, that can bring more oils to the surface than it removes.
These users thanked the author Rodger Knox for the post: Steven Bollman (Tue Sep 17, 2013 2:08 pm)
PostPosted: Tue Sep 17, 2013 2:14 pm
First name: Steven
Last Name: Bollman
City: Emeryville
Thanks, Roger. I used to be a furniture maker so I'm comfortable taking my chances, though I appreciate your advice. Nevertheless, I will dang the torpedoes and try mightily for a good result. What's interesting and not surprising...I read on another forum that it was best to sand the surface and then wipe with a solvent, letting it wick away right before gluing. There are many opinions (some better than others, obviously), and I'm trying to sort out the soundest approach. I really appreciate your response.
PostPosted: Tue Sep 17, 2013 2:19 pm
Last Name: Collins
City: Argyle
State: New York
Zip/Postal Code: 12809
Fish or Hide glue;
the open time of these two will allow the glue to seep
into the pores.
Titebond 1 or the new Ellmers Carpenter glue.
Mike Collins
These users thanked the author Mike Collins for the post: Steven Bollman (Tue Sep 17, 2013 2:25 pm)
PostPosted: Tue Sep 17, 2013 2:28 pm
At the price of BRW these days perhaps Russian Sturgeon Glue (Isinglass) would be the most appropriate? laughing6-hehe
PostPosted: Tue Sep 17, 2013 2:29 pm
First name: Steven
Last Name: Bollman
City: Emeryville
Mike Collins wrote:
Fish or Hide glue;
into the pores.
Thanks, Mike!
PostPosted: Tue Sep 17, 2013 2:36 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Yes, there's quite a few places that recommend wiping with solvent prior to glueing. A number of discussions here and on ther forums have concluded that for guitars, it's not a good idea, that's why I mentioned it.
I built quite a few pieces of furniture before I built my first guitar, and they are different! For furniture work, 1/16" is close enough for almost everything. For a guitar, 1/16" is not close enough for anything! bliss
These users thanked the author Rodger Knox for the post: Steven Bollman (Tue Sep 17, 2013 3:02 pm)
PostPosted: Tue Sep 17, 2013 2:52 pm
Steven, I first got into guitar building after a few years of furniture making. Although some of the skills and techiques of furniture making are transferrable, there are a lot of new things you will need to learn. Also, as Rodger indicated, the tolerances for measurements, as well as perfection, are completely different.
Your first guitar may turn out great, but only if you take advantage of the available information and books on the subject, plus develop a perfectionist approch to each step.
These users thanked the author Barry Daniels for the post: Steven Bollman (Tue Sep 17, 2013 3:02 pm)
PostPosted: Tue Sep 17, 2013 3:07 pm
First name: Steven
Last Name: Bollman
City: Emeryville
Thanks Rodger. I am taking the long, slow approach to completion. No artificial deadlines. I actually worked with much tighter than 1/16" tolerances, but that's due to a selective-perfectionistic streak.
PostPosted: Tue Sep 17, 2013 3:09 pm
First name: Steven
Last Name: Bollman
City: Emeryville
Thanks, Barry! I appreciate your perspective and will take it to heart.
PostPosted: Tue Sep 17, 2013 5:22 pm
Last Name: Beaver
City: Lake Forest
I have no evidence to show what I am about to say is true and please disregard at will….. but,
Titebond, and many other glues, are well known for creating a bond that is ‘stronger than the wood’. That is not always the case with thin plates. I find that when thin plates are glued together they are not held as tightly as thicker plates would be. In fact the bond of the thin plate may break before the wood falls. I have tested that on cutoffs
We all know that starving a joint of glue is not an issue, other than with epoxy. I think what happens with glues, except probably CA, is that since the plate is so thin, say .150 or less, when under clamping pressure, the joint can be starved. I believe that since the plate is so thin, the glue just has to migrate .07 or so to leave the joint. The glue has to migrate much farther on thicker plates and tends to stay in the joint.
So, to help with the problem I spread a nice bead of titebond and put the plates together but with no clamping pressure. I leave them that way for 4-5 minutes then clamp as normal.
Anyway… it has worked for me.
Joe Beaver
Maker of Sawdust
PostPosted: Tue Sep 17, 2013 6:57 pm
Rodger Knox wrote:
For joining the backs.........Scrape the joint immediately before glueing, that raises the surface energy and improves adhension of the glue.
Sounds like a great way to spoil your hard fought jointery. I joint the pieces just prior to joining.
These users thanked the author Pmaj7 for the post: CraigG (Tue Sep 17, 2013 10:46 pm)
PostPosted: Wed Sep 18, 2013 11:47 am
Quote:
[quote="For furniture work, 1/16" is close enough for almost everything. For a guitar, 1/16" is not close enough for anything! bliss
[/quote]
1/16" ? Really ? I didn't know that.
PostPosted: Wed Sep 18, 2013 12:38 pm
First name: Alex
Last Name: Kleon
City: Whitby
Zip/Postal Code: L1N8X2
Link Van Cleave wrote:
1/16" ? Really ? I didn't know that.[/quote]
If my work was + or - 1/16", I'd be out of business in a hurry, and setting up a table at the high school craft show.
Alex
PostPosted: Wed Sep 18, 2013 2:49 pm
Yep, 1/64" is what I work to on custom furniture. 1/16" is usually ok for trim in a house and 1/8" for framing.
PostPosted: Thu Sep 19, 2013 6:48 pm
First name: David
Last Name: LaPlante
Fortunately, a rosewood to rosewood joint is rare on a guitar. The only one that comes to mind is when two back plates are joined to each other without the use of a decorative strip between them. Or perhaps on rare occasion when a back is made up of three or four pieces.
Usually its mahogany or Spanish cedar to rosewood (linings, kerfings, front and rear blocks, head veneer etc).
As above, Titebond or fish glue is my choice for this.
